Instead of using eppy, I would recommend using an EnergyPlus feature - Energy Management Systems (EMS). This replicates a Building Automation System, which at its core is a combination of:
Each EMS component can use updated information from EnergyPlus at each timestep. There are many posts on Unmet Hours regarding how to use EMS, if you search for EnergyPlus EMS in the Search or ask your question bar at the top of the page or look at posts using the ems question tag.
