you can use the End Use Subcategory on lights and equipment to easily create additional meter outputs in the energy plus report summary report. If you are using OpenStudio, a measure may be required to access the End Use Subcategory on light definitions and equipment definitions. For plant attribution, use output variables measuring volume flow rates. If the buildings are thermally seperate, I would be tempted to have two seperate models. Using that approach you could run one model to get the total ( chilled ? ) water from building A and represent that chw demand on the total plant system with a Load Profile.
