I am having the same issue. I have learned to go to OS to Intersect and Match Surfaces, but then when returning to SU to project loose geometry I am getting the wireframe issue. The model loses all surfaces and is unusable. I don't believe there is a way to project loose geometry directly in OS so I'm at a loss for how to move forward other than manually drawing every window and door. Any suggestions?
