The coils are not required by EnergyPlus for cooling-only or heating-only mode. See the IDD too...
ZoneHVAC:TerminalUnit:VariableRefrigerantFlow,
A11, \field Cooling Coil Object Type
\type choice
\key Coil:Cooling:DX:VariableRefrigerantFlow
\key Coil:Cooling:DX:VariableRefrigerantFlow:FluidTemperatureControl
\note Cooling Coil Type must be Coil:Cooling:DX:VariableRefrigerantFlow
\note if AirConditioner:VariableRefrigerantFlow is used
\note to model VRF outdoor unit
\note Coil:Cooling:DX:VariableRefrigerantFlow:FluidTemperatureControl
\note if AirConditioner:VariableRefrigerantFlow:FluidTemperatureControl or
\note if AirConditioner:VariableRefrigerantFlow:FluidTemperatureControl:HR
\note is used to model VRF outdoor unit
\note This field may be left blank if heating-only mode is used
A13, \field Heating Coil Object Type
\type choice
\key Coil:Heating:DX:VariableRefrigerantFlow
\key Coil:Heating:DX:VariableRefrigerantFlow:FluidTemperatureControl
\note Heating Coil Type must be Coil:Heating:DX:VariableRefrigerantFlow
\note Coil:Heating:DX:VariableRefrigerantFlow:FluidTemperatureControl
\note This field may be left blank if cooling-only mode is used
\type choice
\type choice
PS - if you want to avoid casting optional objects to their specific class, you can use Julien's dirty method.
