Are you interested in average chiller COP from the annual simulation or chiller COP at rated conditions?
Chiller values are listed under the Central Plant table in the Equipment Summary report. There are IPLV values and nominal efficiency. If you want run time efficiency, use the Chiller COP Output:Variable.
