Hi There, it should be possible in DesignBuilder (DB) to remove the area of a zone from your totals by excluding the floor surface area from your total zone floor area. Do this as follows:
After that, try your report again to see if it worked. The above steps are based on DB not being in Learning Mode. You may need to go to Tools | Program Options and uncheck "Learning" checkbox if the above steps do not match your interface. Cheers, Andy
