You can adjust Server Instance Type, Worker Instance Type, and/or Number of Workers (in the Remote Server Settings dropdown) according to the size of your analysis. For example, smaller analyses may require the c3.8xlarge server instance type, whereas larger analyses may require the d2.4xlarge server instance type and additional workers.
This is documented on the ResStock RTD website: https://resstock.readthedocs.io/en/latest/aws_cluster_config.html.
