I think it depends on if the garage is conditioned or not. See the definitions...
building envelope: the exterior plus the semi-exterior portions of a building. For the purposes of determining building envelope requirements, the classifications are defined as follows:
exterior building envelope: the elements of a building that separate conditioned spaces from the exterior.
exterior building
envelope:envelope: the elements of a building that separate conditioned spaces from the exterior.
Also, OpenStudio Standards adjusts the baseline WWR based on whether the space is conditioned.
