I don't think you can add a new curve to the library that will show up in other projects. You can create a custom curve though. If you want to user that curve on multiple systems, you can copy the team with the custom curve.
You could always create the custom fans, dx, and hp curves and export them with a system to import on other projects.
I don't think you can add a new curve to the library that will show up in other projects. You can create a custom curve though. If you want to user use that curve on multiple systems, you can copy the team with the custom curve.
I don't think you can add a new curve to the library that will show up in other projects. You can create a custom curve though. If you want to use that curve on multiple systems, you can copy the team fan with the custom curve.curve to other systems.
