Both HDD and CDD can be obtained via the "weather" utility in the EP Launch Utilities tab. You ask for a statistic report of your EPW filke, and it createas such statistic report.
As for CDD and HDD, close to the end of the file you find these lines (taken from one of my local climate files):
- Heating/Cooling Degree Days/Hours calculated from this weather file.
- Heating/Cooling Degree Days/Hours from design conditions shown earlier in this report.
- Monthly Weather File Heating/Cooling Degree Days/Hours
Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov Dec
HDD base 10C 0 0 0 0 0 0 0 0 0 0 0 0
HDD base 18C 87 39 10 0 0 0 0 0 0 9 51 99
CDD base 10C 162 207 293 367 425 381 356 341 309 292 201 149
CDD base 18C 1 21 55 127 177 141 108 93 70 53 12 0
CDH base 20C 660 1062 1837 2885 3505 2610 1995 1745 1388 1427 849 574
CDH base 23C 215 510 940 1759 2133 1392 879 715 514 666 318 199
CDH base 27C 9 127 244 706 871 431 150 71 73 130 22 9
- 3484 annual (wthr file) cooling degree-days (10°C baseline)
- 0 annual (wthr file) heating degree-days (10°C baseline)
- 858 annual (wthr file) cooling degree-days (18°C baseline)
- 294 annual (wthr file) heating degree-days (18°C baseline)
files, please note that formatting in this post is not exactly the one in the file):
Days/Hours
As for CDD and HDD, close to the end of the file you find these lines (taken from one of my local climate files, please note that formatting in this post is not exactly the one in the file):
- file):
Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov 0 annual (wthr file) heating degree-days (10°C baseline)
- baseline)
- baseline)
| 4 | No.4 Revision |
Both HDD and CDD can be obtained via the "weather" utility in the EP Launch Utilities tab. You ask for a statistic report of your EPW filke, and it createas such statistic a report.
As for CDD and HDD, close to the end of the file you find these lines (taken from one of my local climate files, please note that formatting in this post is not exactly the one you get in the file):
| 5 | No.5 Revision |
Both HDD and CDD can be obtained via the "weather" utility in the EP Launch Utilities tab. You ask for a statistic report of your EPW filke, and it createas he utility creates such a report.
