You would place the heating coil in the outdoor air system equipment list.
AirLoopHVAC:OutdoorAirSystem,
  OA Sys 1,                !- Name
  OA Sys 1 Controllers,    !- Controller List Name
  OA Sys 1 Equipment,      !- Outdoor Air Equipment List Name
  VAV Sys 1 Avail List;    !- Availability Manager List Name
AirLoopHVAC:OutdoorAirSystem:EquipmentList,
  OA Sys 1 Equipment,      !- Name
  Coil:Heating:Electric,   !- Component 1 Object Type
  My OA Heating Coil,      !- Component 1 Name
  OutdoorAir:Mixer,        !- Component 2 Object Type
  OA Mixing Box 1;         !- Component 2 Name
click to hide/show revision 2
No.2 Revision
You would place the heating coil in the outdoor air system equipment list. Not all coil types are allowed. For example, a DX coil would need to be wrapped in a CoilSystem object.
  OA Sys 1,                !- Name
Valid coil types in the outdoor air system:
ZoneHVAC:OutdoorAirUnit:EquipmentList,
   \memo Equipment list for components in a ZoneHVAC:OutdoorAirUnit. Components are simulated
   \memo sequentially in the order given in the equipment list.
A1 , \field Name
   \required-field
   \type alpha
   \reference OutdoorAirUnitEquipmentLists
A2 , \field Component 1 Object Type
   \type choice
   \key Coil:Heating:Electric
   \key Coil:Heating:Fuel
   \key Coil:Heating:Steam
   \key Coil:Heating:Water
   \key Coil:Cooling:Water
   \key Coil:Cooling:Water:DetailedGeometry
   \key CoilSystem:Cooling:Water:HeatexchangerAssisted
   \key CoilSystem:Cooling:DX
   \key CoilSystem:Heating:DX
   \key HeatExchanger:AirToAir:FlatPlate
   \key HeatExchanger:AirToAir:SensibleAndLatent
   \key Dehumidifier:Desiccant:NoFans
   \key AirLoopHVAC:UnitarySystem
A3 , \field Component 1 Name
click to hide/show revision 3
No.3 Revision
  OA Sys 1,                !- Name
A1 , \field Name
   \required-field
   \type alpha
   \type choice
CoilSystem:UserDefined
click to hide/show revision 4
No.4 Revision
You would place the heating coil in the outdoor air system equipment list. Not all coil types are allowed. For example, a DX coil would need to be wrapped in a CoilSystem object.object. Coils in the outdoor air system are always set point based control, meaning that a set point manager is used to place a temperature set point at the coil outlet node.
  OA Sys 1,                !- Name
Coil:Heating:Fuel
Coil:Heating:Steam
Coil:Heating:Water
Coil:Cooling:Water
click to hide/show revision 5
No.5 Revision
You would place the heating coil in the outdoor air system equipment list. Not all coil types are allowed. For example, a DX coil would need to be wrapped in a CoilSystem object. Coils in the outdoor air system are always set point based control, meaning that a set point manager is used to place a temperature set point at the coil outlet node.
  OA Sys 1,                !- Name
Coil:Heating:Fuel
Coil:Heating:Steam
Coil:Heating:Water
Coil:Cooling:Water
Valid non-coil types in the outdoor air system: OutdoorAir:Mixer Fan:SystemModel Fan:ComponentModel Fan:VariableVolume (scheduled for deprication after V9.2) Fan:ConstantVolume (scheduled for deprication after V9.2) AirLoopHVAC:UnitarySystem HeatExchanger:AirToAir:FlatPlate HeatExchanger:AirToAir:SensibleAndLatent HeatExchanger:Desiccant:BalancedFlow Dehumidifier:Desiccant:NoFans Humidifier:Steam:Electric SolarCollector:UnglazedTranspired SolarCollector:FlatPlate:PhotovoltaicThermal EvaporativeCooler:Direct:CelDekPad EvaporativeCooler:Indirect:CelDekPad EvaporativeCooler:Indirect:WetCoil EvaporativeCooler:Indirect:ResearchSpecial
click to hide/show revision 6
No.6 Revision
  OA Sys 1,                !- Name
Coil:Heating:Fuel
Coil:Heating:Steam
Coil:Heating:Water
Coil:Cooling:Water
Valid non-coil types in the outdoor air system: system:
OutdoorAir:Mixer
 Fan:SystemModel
 Fan:ComponentModel
