Here's a lightly tested Python script (using eppy) for EnergyPlus. Depending on your model, you may want to add filters (e.g. Construction:InternalSource, Material:NoMass, etc.).
import os
from eppy.modeleditor import IDF
idd_dir = r'C:\EnergyPlusV9-1-0'
idd_file = r'Energy+.idd'
idd_path = os.path.join(idd_dir, idd_file)
idf_dir = r'C:\WORK\18151 DEN Level 4\18151-Baseline\run'
idf_file = r'in.idf'
idf_path = os.path.join(idf_dir, idf_file)
IDF.setiddname(idd_path)
idf = IDF(idf_path)
total_heat_capacity = 0
surfaces = idf.idfobjects['BuildingSurface:Detailed'.upper()]
# loop through the surfaces to calculate heat capacity
for surface in surfaces:
construction_heat_capacity = 0
construction = idf.getobject('CONSTRUCTION', surface.Construction_Name)
# get the field names, which is a list of ['key', 'Name', 'Outside_Layer', 'Layer_2', ... 'Layer_10']
construction_field_names = construction.fieldnames
# loop through the construction's field names (layers), skipping first and second (key and Name)
for field_name in construction_field_names[2:]:
# get the material object from the layer
attribute = field_name
material_name = getattr(construction, attribute)
material = idf.getobject('MATERIAL', material_name)
# calculate the material's heat capacity and add it to the construction's
if material is not None:
thickness = material.Thickness
density = material.Density
specific_heat = material.Specific_Heat
material_heat_capacity = thickness * density * specific_heat
construction_heat_capacity += material_heat_capacity
# add the construction's total heat capacity to the model's total
total_heat_capacity += construction_heat_capacity
print('J/m2*K =', total_heat_capacity)
References from OpenStudio
import os
idf = IDF(idf_path)
# ['key', 'Name', 'Outside_Layer', 'Layer_2', ... 'Layer_10']
# skipping first and second (key and Name)
To do it programmatically, you could either use OpenStudio and Ruby or EnergyPlus and Python.
OpenStudio and Ruby
Import the IDF to OpenStudio and as @luis lara suggested run a Ruby script (or formal OpenStudio Measure) on the OpenStudio model
import os
idf = IDF(idf_path)
| 4 | No.4 Revision |
OpenStudio and Ruby
Import the IDF to OpenStudio and as @luis lara suggested run a Ruby script (or formal OpenStudio Measure) on the OpenStudio modelmodel.
Here's a lightly tested Python script (using eppy) for EnergyPlus. ). Depending on your model, you may want to add filters (e.g. Construction:InternalSource, Material:NoMass, etc.).
import os
idf = IDF(idf_path)
| 5 | No.5 Revision |
OpenStudio and Ruby
Import the IDF to OpenStudio and as @luis lara suggested run a Ruby script (or formal OpenStudio Measure) on the OpenStudio model.
Here's a lightly tested Python script (using eppy). Depending on your model, you may want to add filters (e.g. Construction:InternalSource, Material:NoMass, etc.).
import os
idf = IDF(idf_path)
# get the field names, which in eppy is a list of
