Connectors are used in dual duct air loops which are built using multiple branch objects. See example file DualDuctConstVolDamper.idf. As far as I know, only a Connector:Splitter can be used in an air loop. A Connector:Mixer is not supported.
AirLoopHVAC:ZoneSplitter and AirLoopHVAC:ZoneMixer objects are used in AirLoopHVAC:SupplyPath and AirLoopHVAC:ReturnPath.
