Adding Output:Table:Monthly might be helpful. A table for the meter you specified in the object would be added to the html report. You could also add Output:Variable with a reporting frequency of "Monthly". Hope it helps.
Adding Output:Table:Monthly might be helpful. A table for the meter you specified in the object would be added to the html report. You could also add Output:Variable with a reporting frequency of "Monthly". "Monthly" depending on what you want to report. Hope it helps.
