You are entirely correct on the consequences of moving out of OpenStudio into modifying IDF files directly. The use of EnergyPlus measures is our current solution to this issue. You might try making an EnergyPlus measure, the example shown in the measure writing guide has an example of adding IDF text directly to your file.
