I would say that Radiance is too 'sophisticated' for what you want to achieve here. It has quite a steep learning curve. If I understand correctly you want to obtain the fraction of a window's surface area that is exposed to direct solar radiation.
Some tools/methods with which you can obtain this:
![]() | 2 | No.2 Revision |
