Those errors indicate that the space referenced by surface 343 is missing in the OSM file, did you modify the OSM model by hand in a text editor? The first thing to try should be running the diagnostic user script:
To run the script, go to the "User Scripts" menu under the SketchUp Plugins menu, "Plugins / OpenStudio" menu and choose "OSM Diagnostic Script".
