Do you have any EnergyPlus measures in your workflow when running through OpenStudio? When you export an IDF file, it exports it from the current OSM, prior to any measures being applied to it. If that isn't the case then the next thing I would look at is if the EP Launch run is using a different weather file. While an OSM file has link to EPW file, in EP Launch you have specify that similar to how you specify the IDF file.
