In addition to constructions the OpenStudio Application also allows you to import VRF indoor and outdoor units from the Building Component Library. That functionality is described here. After downloading the components you will see them in the your local library from the OS application. You can drag newly downloaded terminals into an existing system. Generally VRF GUI interface is described on this YouTube video.
