The object Thermostat:OperativeTemperature is not available in OpenStudio. You can use the following energyplus measure to transform the ThermostatSetpointDualSetpoint that is available from openstudio into Thermostat:OperativeTemperature.
https://bcl.nrel.gov/node/82786
