eppy will be able to run energyplus on multiple cores. It is not well documented in the user documentation - see https://eppy.readthedocs.io/en/latest/runningeplus.html#running-in-parallel-processes.
You may be able to figure it out from the code and the unit tests
We would be mighty obliged if you can help improve the documentation.
