Do you have single-zone HVAC systems, or a multi-zone system with terminal units?
If you have single-zone systems, you can just output the heating/cooling coil energy for each system: Output:Variable,,Cooling Coil Total Cooling Energy,hourly; !- HVAC Sum [J] Output:Variable,,Heating Coil Heating Energy,hourly; !- HVAC Sum [J]
If you have a multi-zone system, you'd have to sum the sensible and latent loads. You can output the sensible loads for each zone using: Output:Variable,,Zone Air Terminal Sensible Heating Energy,hourly; !- HVAC Sum [J] Output:Variable,,Zone Air Terminal Sensible Cooling Energy,hourly; !- HVAC Sum [J]
The latent loads can be output using: Output:Variable,,Zone Total Internal Latent Gain Energy,hourly; !- Zone Sum [J] Output:Variable,,Zone Infiltration Total Heat Gain Energy,hourly; !- HVAC Sum [J]
Output:Variable,,Cooling system:
Output:Variable,*,Cooling Coil Total Cooling Energy,hourly; !- HVAC Sum [J]
Output:Variable,,Heating Energy,hourly;
Output:Variable,*,Heating Coil Heating Energy,hourly; !- HVAC Sum [J]Energy,hourly;
Output:Variable,,Zone using:
Output:Variable,*,Zone Air Terminal Sensible Heating Energy,hourly; !- HVAC Sum [J]
Output:Variable,,Zone Energy,hourly;
Output:Variable,*,Zone Air Terminal Sensible Cooling Energy,hourly; !- HVAC Sum [J]Energy,hourly;
Output:Variable,*,Zone Total Internal Latent Gain Energy,hourly; !- Zone Sum [J]
Output:Variable,*,Zone Infiltration Total Heat Gain Energy,hourly; !- HVAC Sum [J]Energy,hourly;
