1 | initial version |
Upsizing the HVAC system to meet the multiplied load is the correct approach. I would suggest using autosize for all autosized inputs and comparing the results with your inputs. You might also try eliminating the height variation as discussed in tips and tricks if you are modeling height variation. Your proposed model does not use multipliers?
