You could build up a model and assign ideal loads systems to each zone. This would tell you the heating and cooling loads associated with whatever indoor conditions you specify.
You could build up a model and assign ideal loads systems to each zone. This would tell you the heating and cooling loads associated with whatever the indoor conditions you specify.
