There are know issues with the performance of the Floorspace JS editor in the OpenStudio application. There is an additional issue in 2.8.0 preventing the editor from launching on mac, which we hope to address in a 2.8.x installer.
There is a work around that leverages an online development version of FloorspaceJS. This should be much more responsive than what is in the OpenStudio application. It isn't about this being newer, but rather about web rendering engine within the application. To use this workflow follow the steps below closely.
  1. Launch OpenStudio 2.7.0 (on Windows you can use 2.8.0)
  2. Go to The Geometry tab and then the Editor sub tab. Click on new and then choose Create a new floorplan.
  3. Save and close your model and quit the Application
  4. In a web browser (preferably Chrome) go to https://nrel.github.io/floorspace.js/
  5. Choose the Create a new floorplan option
  6. Near the top left of the interface are three buttons with arrows in a circle. Use the third button that looks like a puzzle piece to import library. Point it to the floorspace.json file you made in step 2. This will be in thefiles` directory next to your OSM file.
  7. Work in the web interface as you would in the app. To save your json file choose the second button from the left at the top left corner of the interface with the arrow pointing up to save floorplan to your local computer in your Downloads directory. Don't work for an 2 hours and then do this, do it every 10-15 minutes, or more frequently to avoid losing any work.
  8. When you are done working on the plan copy the file from your Downloads directory into the "files" directory of your OSM, making sure the file is a named 'floorspace.json`.
  9. Launch OpenStudio again (same version as step 1).
  10. Go back to the Geometry tab and the Editor sub tab. You should see the plan you created online. Choose Merge with Current OSM to create the OpenStudio spaces and other additional objects defined in FloorspaceJS
Notes:
A. Steps 1-3 are only necessary to bring over data from any space types, constructions, zones, or other resources from your model into the web interface. There is an Open existing floorplan open in the OpenStudio application's geometry editor tab when you click new. This can only be used if you do not already setup a new plan. Otherwise you need to overwrite the file manually as described in step 8, while the application is not open.
B. If you want to go back and edit your plan at a later date you may be able to load the floorspace.json file into the web interface. It may be wise to keep a clean copy outside of what is in the OpenStudio Applicaiton's files directory.
New plan
Web drawn plan
Plan in app
  7. Work in the web interface as you would in the app. To save your json file choose Choose the second button from the left at the top left corner of the interface with the arrow pointing up to save floorplan to your local computer in your Downloads directory. Don't work for an 2 hours and then do this, do it every 10-15 minutes, or more frequently to avoid losing any work.
Notes:
B.
B. C. If you want to go back and edit your plan at a later date you may be able to load the floorspace.json file into the web interface. It may be wise to keep a clean copy outside of what is in the OpenStudio Applicaiton's files directory.directory for this.
New plan
Web drawn plan
Plan in app
