This is a weird problem. I have encountered the same problem, and I solved this by changing the "Central Cooling Design Supply Air Humidity Ratio" of Sizing:System, from 0.008(by default) to 0.01. Actually, I don't understand the underlying reason for this modification, but anyway it works.
