1 | initial version |
The only equipment in a chilled water loop that should add heat to the loop is the pump. I suggest adding:
Output:Diagnostics, ReportDuringWarmup;
to your input file and then examining how the plant loop temperature changes as the simulation warms up. Include the pump inlet and outlet node temperatures to see the pump heat.
