In the spaces tab, in the surfaces "sub-tab," there was a blackened construction for one or more of the floors, showing that it was not a default construction. After "X'ing" this out (in the far upper right), default constructions for floors appeared. They also changed normally when I made changes in an internal source construction in the constructions tab. It is possible this was the solution; I can't be sure, but this problem is gone and energy use is consistent now with floor construction as I change insulation and floor covering.
