You need to keep the "ruby" part of the command as that is the program being executed. Otherwise it thinks you simply want to view the ruby script in a text editor. Also, rather than deviating from the ResStock instructions, I would suggest you issue the command as specified (ruby resources/run_sampling.rb ...) from the parent directory to the resources directory.
