I believe this is because the method peoplePerFloorArea returns an optional double (see here). Check out the chapter "Optionals and .get" from the Measure Writing Guide.
I believe this is because the method peoplePerFloorArea returns an optional double (see here). Check out the chapter section "Optionals and .get" from the Measure Writing Guide.
I believe this is because the The method returns an optional double (see peoplePerFloorAreapeoplePerSpaceFloorAreaherePeopleDefinition Class Reference). Check out the section "Optionals and .get" from the Measure Writing Guide, and @David Goldwasser's answer.
*Edit to correct method name
| 4 | No.4 Revision |
The method returns an optional double (see PeopleDefinition Class Reference). Check out the section "Optionals and .get" from the Measure Writing Guide, and @David Goldwasser's answer.peoplePerSpaceFloorAreapeopleperSpaceFloorArea
