From the warning, Construction object with name = Construction 1 has a missing required input for field outside layer.
From the IDD file, this input is a required field. The next several fields are not required unless there is more than 1 layer, then those are required as well.
Construction,
\memo Start with outside layer and work your way to the inside layer
\memo Up to 10 layers total, 8 for windows
\memo Enter the material name for each layer
A1 , \field Name
\required-field
\type alpha
\reference ConstructionNames
A2 , \field Outside Layer
\required-field
\type object-list
\object-list MaterialName
A3 , \field Layer 2
\type object-list
