Your IDF has several Schedule:File objects, so I can't run it, but I do see that your AirflowNetwork:SimulationControl object has the control field set to MultizoneWithoutDistribution, which is probably not what you want. Set that to MultizoneWithDistribution and see if you get a better result or better error message. It's possible that EnergyPlus is getting confused by some other problem and not quite giving you the feedback you need.
