You have a blank Fenestration Surface Name in the extensible list at the end of your WindowShadingControl with a name Persianas 30%.
For example, the following should give the same error message. Note the missing name in Fenestration Surface 4 Name:
WindowShadingControl,
DOUBLE PANE WITH SCREEN-DPWB, !- Name
DPWB, !- Zone Name
1, !- Shading Control Sequence Number
ExteriorScreen, !- Shading Type
DOUBLE PANE WITH SCREEN, !- Construction with Shading Name
OnIfScheduleAllows, !- Shading Control Type
ScreenSchedule, !- Schedule Name
20.0, !- Setpoint {W/m2, W or deg C}
YES, !- Shading Control Is Scheduled
NO, !- Glare Control Is Active
, !- Shading Device Material Name
, !- Type of Slat Angle Control for Blinds
, !- Slat Angle Schedule Name
, !- Setpoint 2 {W/m2 or deg C}
, !- Daylighting Control Object Name
Sequential, !- Multiple Surface Control Type
Zn003:Wall001:Win001, !- Fenestration Surface 1 Name
Zn003:Wall002:Win001, !- Fenestration Surface 2 Name
Zn003:Wall003:Win001, !- Fenestration Surface 3 Name
; !- Fenestration Surface 4 Name
