Dear Raphael,
I followed your suggestion, but there is something strange within the evaluated schedule after applying EMS coding on the transparency shading schedule.
As you see here I defined three ranges to control the shading transparency based on the 'Surface Outdoor Face Sunlit Fraction' which in my case I selected the external window surface as a sample.
S1, !- Name
zone_0_Srf_0_glz_0, !- Output:Variable or Output:Meter Index Key Name
Surface Outside Face Sunlit Fraction ; !- Output:Variable or Output:Meter Name
EnergyManagementSystem:Actuator,
myA1, !- Name
ASF, !- Actuated Component Unique Name
Schedule:Year, !- Actuated Component Type
Schedule Value; !- Actuated Component Control Type
MyComputedTransProg, !- Name
BeginTimestepBeforePredictor, !- EnergyPlus Model Calling Point
MyComputedTransSch; !- Program Name 1
MyComputedTransSch, !- Name
Set SurfaceFraction = S1,!- Program Line 1
IF SurfaceFraction < 0.3,!- Program Line 2
SET myA1 = 0.9, !- A4
ELSEIF (SurfaceFraction >= 0.3) && (SurfaceFraction < 0.8), !- A5
SET myA1 = 0.4, !- A6
ELSE, !- A7
SET myA1 = 0.1 , !- A8
ENDIF; !- A9
EnergyManagementSystem:GlobalVariable,
myglobeA1; !- Erl Variable 1 Name
EnergyManagementSystem:OutputVariable,
Weighted Shade Fraction Schedule, !- Name
myglobeA1, !- EMS Variable Name
Averaged, !- Type of Data in Variable
SystemTimestep; !- Update Frequency
But, when I see the results, everyday I obtain a strange number out of the ranges I defined with EMS in the beginning and ending hour of the daytime.
Did I do sth wrong in the definition?
Regards Amir
Dear Raphael,
S1, !- Name
myA1, !- Name
ELSE, !- A7
ENDIF; !- A9
But, when I see the results, everyday I obtain a strange number out of the ranges I defined for Transparency SCH with EMS in the beginning and ending hour of the daytime.
Regards Amir
Dear Raphael,
S1, !- Name
myA1, !- Name
ELSE, !- A7
ENDIF; !- A9
But, when I see the results, everyday I obtain a strange number numbers out of the ranges I defined for Transparency SCH with EMS in the beginning and ending hour of the daytime. Like in below I got 0.76666 and 0.3666 for which based on my definition in EMS-Program and sunlit fractions must be 0.9 and 0.1 respectively.
Regards Amir
| 4 | No.4 Revision |
Dear Raphael,
S1, !- Name
myA1, !- Name
ELSE, !- A7
ENDIF; !- A9
But, when I see the results, everyday I obtain a strange numbers out of the ranges I defined for Transparency SCH with EMS in the beginning and ending hour of the daytime. Like in below I got 0.76666 and 0.3666 for 0.3666, which based on my definition in EMS-Program and sunlit fractions must be 0.9 and 0.1 respectively.
Regards Amir
| 5 | No.5 Revision |
Dear Raphael,
S1, !- Name
myA1, !- Name
ELSE, !- A7
ENDIF; !- A9
But, when I see the results, everyday I obtain a strange numbers out of the ranges I defined for Transparency SCH with EMS in the beginning and ending hour of the daytime. Like in below I got 0.76666 and 0.3666, which based on my definition in EMS-Program and sunlit fractions must be 0.9 and 0.1 respectively.
Regards Amir
