Since the Energy+.schema.epJSON is generated directly from the IDD then compiled into the executable, it is not possible to change it without recompiling EnergyPlus. The IDD and Energy+.schema.epJSON provided with the installer are for informational purposes only. Changing either of them will not alter the compiled schema.
In your specific instance, there is not a max number of extensible fields in the Energy+.schema.epJSON for ZoneTerminalUnitList. In the Energy+.schema.epJSON, look for minProperties, maxProperties, minItems, and maxItems; these are the only limits on the number of fields/items in the schema.
