If you wanted the monthly and annual averages during certain time windows, then you could use Output:Table:Monthly with the following columns:
HoursPositiveSumOrAverageDuringHoursShown - this will average during the hours counted in the previous column.But if this is supposed to be the maximum 3-day moving average, you'll need to use an EMS (EnergyManagementSystem:*) program to do the calculations and generate a custom output variable. If you want the result for that to end up in the html output, you can use Output:Table:Monthly to report the monthly and annual maximum of the custom EMS output variable.
I also considered using UtilityCost:Ratchet but I don't see a way to set the demand window to 9 hours.
