@macumber was on the right track with a nil value being passed into the log message. The cause for this is that the AEDG measures (school and office) both have space type specific recommendations for lighting controls. Your two space types use "WholeBuilding - Sm Office" for the standards space type. As a result no lights are found that the measure can make a recommendation for. The measure should behave better and issue a not applicable warning, that no lights of the appropriate space types were found, and that the model wont' be altered, I'll file an issue to fix that. It will likely affect the lighting or equipment controls AEDG measures for school and offices.
If you change the standards space types instead to "ClosedOffice" or "OpenOffice" the measure should run fine. Ideally if you break the building down by space type showing spaces such as corridors, lobbies, etc. you will get more specific recommendations.
I also noticed on the facility tab that the "Standard Building Type" for the building was blank. Some measure, in particular the AEDG exterior light measures will need to know that to function properly. It doesn't attempt to infer it from space types in the building which may include types from more than one building.
@macumber was on the right track with a nil value being passed into the log message. The cause for this is that the AEDG measures (school and office) both have space type specific recommendations for lighting controls. Your two space types use "WholeBuilding - Sm Office" for the standards space type. As a result no lights are found that the measure can make a recommendation for. The measure should behave better and issue a not applicable warning, that no lights of the appropriate space types were found, and that the model wont' be altered, I'll file an issue to fix that. It will likely affect the lighting or and equipment controls AEDG measures for school schools and offices.
@macumber was on the right track with a nil value being passed into the log message. The cause for this is that the AEDG measures (school and office) both have space type specific recommendations for lighting controls. Your two space types use "WholeBuilding - Sm Office" for the standards space type. As a result no lights are found that the measure can make a recommendation for. The measure should behave better and issue a not applicable warning, that no lights of the appropriate space types were found, and that the model wont' be altered, I'll file an issue to fix that. It will likely affect the lighting and equipment controls AEDG measures for schools and offices.
The template SpaceTypes in OpenStudio are pre-popluated with the standard building type and space type names. You can add these to space types you make as well in the "Measure Tags" view of the space types grid-view. Shown below are the office standards space types from our templates.
| 4 | No.4 Revision |
