If the windows are in a repetitive pattern, you can draw wireframes in your model and copy+paste them in Sketchup, then use 'Project Loose Geometry' to make them into windows on your facade. It helps to make the wireframes away from the zones to make the copy-selection easier, then drag them to overlay the facade when you are ready to project the geometry.
If you have a 25 storey building, you can use Zone Multipliers to save having to repeat geometry.
