Thank you for your answer.
I have already tried these objects but the problem is that I want to implement a co-simulation scheme in which I should be able to control my Heat Pump from matlab through bcvtb and give "from outside" the values of fan speed and inlet damper position (or even compressor speed) for the heat pump. From what I have seen, these capabilities are not given in energyplus objects of HP: it is necessary to define a certain thermostat and you cannot control the fan speed and inlet damper opening .
kind regards
