Just guessing, but it appears that most of the HVAC objects in this file are not autosized and have values entered for flow rates, capacities, etc. In v8.5 and prior, the Branch object had a field for "Maximum Flow Rate" which apparently has been set to "autosize" in this file. Find the flow rate value entered for the other components on this airloop and use that value here.
Note that the "Maximum Flow Rate" field was removed from the Branch object in v8.6 and later.
