You can easily add objects to the default Openstudio libraries. You can create your own space types when you open your Model in the Openstudio Graphical User Interface, and also assign them. You can find the default libraries in the Preferences Menu of Openstudio.
Once you create this space types, you can copy and paste it in one of the default .osm libraries or add your own .osm file with your space types. You can see below, I have some custom libraries (which are .osm files) with code definitions, but the space type works the same.
