Try loading only the inp file: When you open eQUEST, click on "Select and Existing Project to Open". Then, in the dropdown box located at the bottom right corner select "DOE-2.2 BDL Input Files" and point to your inp file. Once the model has been loaded, change the weather file in the project properties if you haven't done it when you loaded your inp file.
By doing that you'll loose everything that was in you pd2 file, however, the pd2 file contains pretty much only information about what was selected in the Wizard. If you are reviewing the model in the detail interface, you probably don't need to know what was selected in the Wizard.
