Currently the shading surface in OpenStudio does have a field to store the base surface.
The overhang user script and measure do name the surface after the subsurface object it is made I over. You use an
Currently the shading surface in OpenStudio does doesn't have a field to store the base surface.
Currently the shading surface in OpenStudio doesn't have a field to store the base surface.
The overhang user script and measure do name the surface after the subsurface object it is made I over. You can use an Energy Plus measure add the additional.
| 4 | No.4 Revision |
The overhang user script and measure do name the surface after the subsurface object it is made I over. above. You can use an Energy Plus measure add the additional.additional data.
