Turns out that putting the pump object before the TemperingValve rather than after in the plantloop resulted in no errors from energyplus. This is not explicitly stated in the IO Reference, but other objects have similar conditions on relative placement of dependent objects in loops.
I will report this as a documentation bug.
Here is the working idf file if anyone cares.
