click to hide/show revision 1
initial version
This error is reported when the surface is really small.
Go back into the Openstudio Sketchup Plugin and use the search function to search for Surface x. You will find a really small surface.
Delete the surface and unhide your model. Make sure that this did not delete another surface it was connected to (if it did, just redraw the surface by connecting two vertices.
click to hide/show revision 2
No.2 Revision
Delete the surface and unhide your model. Make sure that this did not delete another surface it was connected to (if it did, just redraw the surface by connecting two vertices.vertices).
