If you call the EnergyPlus CLI with the -h flag, it will display all options:
C:\EnergyPlusV9-0-1\energyplus.exe -h
EnergyPlus, Version 9.0.1-bb7ca4f0da
Usage: energyplus [options] [input-file]
Options:
-a, --annual Force annual simulation
-c, --convert Output IDF->epJSON or epJSON->IDF, dependent on
input file type
(truncated)
Example: energyplus -w weather.epw -r input.idf
The -c or --convert option is used to generate an epJSON file from an IDF. So you can do:
C:\EnergyPlusV9-0-1\energyplus.exe -c in.idf
and it will output the in.epJSON file. Note that it still runs the energy simulation in addition to converting the input file, so if you only want to convert the file, you might modify the IDF so that it doesn't run an annual simulation.
Finally, you can now run the epJSON file like so:
C:\EnergyPlusV9-0-1\energyplus.exe -r in.epJSON
Options:
input file type
(truncated)
The -c or --convert option is used to generate an epJSON file from an IDF. IDF (and vice versa). So you can do:
| 4 | No.4 Revision |
C:\EnergyPlusV9-0-1\energyplus.exe -h EnergyPlus, Version9.0.1-bb7ca4f0da22.1.0-ed759b17ee, YMD=2022.05.05 09:35 Usage: energyplus [options] [input-file] Options: -a, --annual Force annual simulation -c, --convert Output IDF->epJSON or epJSON->IDF, dependent on input file type ... (truncated) ... --convert-only Only convert IDF->epJSON or epJSON->IDF, dependent on input file type. No simulation Example: energyplus -w weather.epw -r input.idf
The or -c--convert--convert-only option is used to generate an epJSON file from an IDF (and vice versa). So you can do:
C:\EnergyPlusV9-0-1\energyplus.exe -c C:\EnergyPlusV22-1-0\energyplus.exe --convert-only in.idf
Finally,
Then you can now run the epJSON file like so:
C:\EnergyPlusV9-0-1\energyplus.exe C:\EnergyPlusV22-1-0\energyplus.exe -r in.epJSON
Alternatively, you can use the --convert or -c option to do both steps (convert the file and run the simulation) at the same time:
C:\EnergyPlusV22-1-0\energyplus.exe -c in.idf
| 5 | No.5 Revision |
C:\EnergyPlusV9-0-1\energyplus.exeC:\EnergyPlusV22-1-0\energyplus.exe -h EnergyPlus, Version 22.1.0-ed759b17ee, YMD=2022.05.05 09:35 Usage: energyplus [options] [input-file] Options: -a, --annual Force annual simulation -c, --convert Output IDF->epJSON or epJSON->IDF, dependent on input file type ... (truncated) ... --convert-only Only convert IDF->epJSON or epJSON->IDF, dependent on input file type. No simulation Example: energyplus -w weather.epw -r input.idf
The --convert-only option is used to generate an epJSON file from an IDF (and vice versa). So you can do:
Then you can run the epJSON file like so:
| 6 | No.6 Revision |
Options:
input file type
(truncated)
