Unfortunately the free tier on AWS no longer works with the latest versions of PAT. However, Amazon on longer charges by the hour, so choosing the cheapest avail AMI in the drop downs and choosing '0' workers will minimize cost for experimenting with PAT. Always remember to double check the EC2 dashboard that your instances are terminated when you are done so you dont get charged extra after you are done :)
Unfortunately the free tier on AWS no longer works with the latest versions of PAT. However, Amazon on no longer charges by the hour, so choosing the cheapest avail AMI in the drop downs and choosing '0' workers will minimize cost for experimenting with PAT. Always remember to double check the EC2 dashboard that your instances are terminated when you are done so you dont get charged extra after you are done :)
