You can add blinds and shading controls in the OpenStudio Application to models created in FloorSpaceJS, however it is a bit nested in the spaces tab. Follow these steps
You should be all set. I''m not 100% sure what happens if you edit the subsurfaces in FloorSpaceJS and then come back to OpenStudio. If you do that you should confirm that shading controls were not lost and if they were lost, file an issue to let us know. For reference screenshot below shows the "Shading Controls" grid view.
