click to hide/show revision 1
initial version
You are correct that the RoomAirSettings:* objects define the UFAD characteristics for the thermal stratification model. Any type of HVAC system can be used with the UFAD model. If I understand correctly, for your application, you would use AirTerminal:SingleDuct:ConstantVolume:NoReheat. For single-zone system, the easiest approach would be to use AirLoopHVAC:UnitarySystem with "Control Type" = Load. This system type accepts any type of heating and cooling coil.
