You can use the existing Inject IDF objects EnergyPlus measure on the OpenStudio Building Component Library to accomplish this. In the OpenStudio application, go to the Measures tab, and add this EnergyPlus measure. For the measure, you will supply a path to a IDF file where only the Site:Precipitation object (and perhaps a Schedule object referenced by it) are in the file.
